Home › Forums › Products › Stompboxes › New Input Volume pedal control › Reply To: New Input Volume pedal control
July 16, 2015 at 4:14 pm
#139753
Thanks Wedelich, good to know that the new DRY/WET routing mode goes a step closer to my and many other delay’s users needs.
Actually after the H9 I have a Strymon Flint in the chain, I’ll try to feed it with a stereo input to see if it sum stereo signals into mono output (not sure about that).
Thinking at how the input volume behave in wet/dry mode do you think it could be easy to make it work the same way in normal mode too with some future programming options/updates?
Thanks again for the tip, ciao.
