Home Forums Products Stompboxes H9 audio issues crunchstation (wont pick up soft signal) Reply To: H9 audio issues crunchstation (wont pick up soft signal)
#139756
jgoldbach
    gregmhoffmann wrote:
    Hey!
    So when I'm playing softly on with the crunchstation engaged it won't pick up my guitar.  It'll pick up some then die out fast.  If I strum hard it misses the attack and It sounds like I'm only getting parts of the signal.  It also wont sustatin when I'm playing hard.  It will fade out and mute.
    Does anyone know how to remedy this?
    Hi Greg,
    Do you have your H9 pedal in your effects loop? If so, that may explain your symptoms. Some effects, like overdrive, don't work or respond very well in the effects loop just like some effects like reverb don't work very well in front of your amp if you use its gain.
