Home › Forums › Products › Stompboxes › H9 audio issues crunchstation (wont pick up soft signal) › Reply To: H9 audio issues crunchstation (wont pick up soft signal)
#139757
wedelich
    gregmhoffmann wrote:
    Hey!
    So when I'm playing softly on with the crunchstation engaged it won't pick up my guitar.  It'll pick up some then die out fast.  If I strum hard it misses the attack and It sounds like I'm only getting parts of the signal.  It also wont sustatin when I'm playing hard.  It will fade out and mute.
    Does anyone know how to remedy this?
    Greg
    That sounds like the new Sag parameter.  It simulates broken stuff.  Is the SAG parameter turned up at all when you are getting this behavior? If not, it could be that youre guitar is rather quiet, and you need to turn the Gate in CrushStation off, or increase the Input Gain on your H9.  Either these things, or as Jay suggested above, could be something with running distortion in an effects loop.
