Home Forums Products Stompboxes Signal is increased/clipping on H9 when changing from post to pre Reply To: Signal is increased/clipping on H9 when changing from post to pre
#139761
    This is one we have also discovered and will not be easy to fix. The problem is that the Crush uses most of the dsp power, and does not leave enough to perform the necessary crossfade when changing PRE/POST.
    We're working on it, but do not have a fix date at this time.
