Home › Forums › Products › Stompboxes › H9 Killdry Bug – Dry Signal Leaks During Preset Changes › Reply To: H9 Killdry Bug – Dry Signal Leaks During Preset Changes
I have an H9 core with latest software (crushstation release) and i use a Boss ES-8 to control program changes via midi. I also have a Space pedal connected over midi in same set up.
When changing presets on the H9, I get a very loud “pop” as the preset switches – and I do mean *loud*
I realize that loading presets is CPU intensive, so I thought I would have the same problems with the Space… but the Space works perfectly when changing presets (no noise whatsoever switching among algo’s).
I’ve tried a few different algo’s on the H9 and the problem is consistent. Changing preset with midi command on H9 produces loud pop. VERY FRUSTRATING.
Any ideas?
