Home › Forums › Products › Stompboxes › AUX Switch Polarity? › Reply To: AUX Switch Polarity?
#139883
peter_heijnen
    I’m about to build an aux switch too. I’d like to use it as a lead boost mostly, make a presets spit out a couple db’s more when engaged. Would that require a ‘normally open’ switch as well?
    I also did a little research on a diy fs300 style switch. I learned that this would require 3 ‘normally closed’ switches. Is that right, and if so what makes the difference?
    Thx in advance!
    Peter.
