Home Forums Products Stompboxes Special Application for H9 MAX Reply To: Special Application for H9 MAX
#139919
styleomatic
gkellum wrote:
I think there are two system settings you'll want to check to make your H9 behave as you want it to.  You'll want to have MIDI clock in enabled and global tempo enabled.  You can double check how these settings are currently set in H9 Control by clicking on the Pedal button in the bottom right hand corner of H9 Control.  The MIDI clock in setting is under MIDI Settings / MIDI Clock, and the Global Tempo setting is under General Settings.
Thanks for the reply. I have done all of the above.
What I’m asking for is to have the delays, tremolos, Undulators etc.. follow and lock into the midi clock.
In other words, is there a patch where the H9 effects can ignore my input from guitar and follow the constant click from an external
midi clock? Thanks
