Home › Forums › Products › Stompboxes › expression pedal ..controlling TF & MF (at the same time?) › Reply To: expression pedal ..controlling TF & MF (at the same time?)
August 1, 2015 at 4:29 am
#139991
nickrose wrote:
You can connect one (1/4″ jack type) expression pedal to both TF and MF via a Y lead.
Or you could use a MIDI pedal to control both units in series (set the first one to MIDI THRU).
This would require them both to be set to the same MIDI channel, which would mean that all MIDI commands (not just the pedal) would be sent to them both. With careful choice of CC or ProgChange values this would be OK.
Hi, one question, I need the same setup one expression for a TF and a MF.
Does this Y adapter work…
It has to be TRS or TS > DUAL TS?
Thanks
