Home › Forums › Products › Stompboxes › expression pedal ..controlling TF & MF (at the same time?) › Reply To: expression pedal ..controlling TF & MF (at the same time?)
August 1, 2015 at 9:00 pm
#139995
The best solution I found to that problem is a midi controler like the DMC-3. I allows you to control with your expression pedal till to 3 stomboxes or just to the one you want.
