Home › Forums › Products › Stompboxes › Compressed SPACE … › Reply To: Compressed SPACE …
#140062
    I’m technically cheating here, but many of the H9 / ‘Factor algorithms can mimic envelope and gating characteristics without an integrated compressor.  Besides, I’ve always been a sucker for these Poltergist / Hendrix type of effects, when used sparingly.
    Expression Pedal Heel Position
    Expression Pedal Heel  MOD-LEVEL  0
    Expression Pedal Toe   MOD-LEVEL  100
    The expression pedal mapping simply folds in the depth of modulation.  One favorite technique is to set TEMPO ON, then play to the reverse reverb in a call-and-response manner.  With precise timing, it’s easy to create complex & overlapping phrases out of sparse input.    Pauses are followed by a sudden ‘gate’ after DECAY time completion.
    Tempo Sync Phrasing [@ Expression Pedal Toe Position]
    Use the HotSwitch here to kick in an infinite dimensional SIZE, and also add a FEEDBACK loop around the entire algorithm.  Detuning and pitch bends can occur over time with expression pedal control over MOD-LEVEL.  A beautiful holding pattern pushing a wall of sound; one that churns and recycles.
    Disengaging the HotSwitch quickly brings up the reverse envelope once again, followed by the ‘gate’ slamming shut.
    HotSwitch On [Expression Pedal at Mid-Travel]
    HotSwitch OFF  SIZE  0
    HotSwitch OFF  FEEDBACK  0
    HotSwitch ON    SIZE  INF
    HotSwitch OFF   FEEDBACK 100
