Home › Forums › Products › Stompboxes › Midi merge pass through midi clock? › Reply To: Midi merge pass through midi clock?
August 9, 2015 at 1:26 pm
#140072
… but MIDI Clock is channel independent. That is – as a System Real Time message -it would be received no matter what MIDI Channel is dialed in. MIDI Clock is always ‘Omni’, so you should be all set (assuming that all other MIDI Clock options are set up correctly in both H9’s).
