Reply To: Using Eventide pedals with MFC-101 midi controller
Home Forums Products Stompboxes Using Eventide pedals with MFC-101 midi controller Reply To: Using Eventide pedals with MFC-101 midi controller
#140262
trancegodz
Well I couldn’t get it to work right using a cc to change the Eventide toggle like support suggested, but I got it to turn on and off with one press using a cc to change the bypass state. The problem now is that the Eventide effect is always on when I switch presets. So if I hit the unlit IA I programmed to bypass bypass the Eventide, the MFC IA light is on when the Eventide effect is off, and off when the Eventide effect is on.
Are any of you successfully using a Fractal MFC-101 with multiple Eventide pedals? If so how are you setting it up? I’m starting to think I may need to buy a different midi controller. Do you also need something like an effects gizmo if you are trying to control multiple Eventide pedals?
