Home › Forums › Products › Rackmount › Configuring H8000FW for dual-stereo using ADAT › Reply To: Configuring H8000FW for dual-stereo using ADAT
September 5, 2015 at 7:45 am
#140425
If you use the "ADAT 8 Track A,B"" factory routing, this will give you dual 4 channel routing. TYou can ignore channels 3,4 on ech to give stereo. You may need to mess with the input routing to pick off the correct ADAT channels.
