Home › Forums › Products › Stompboxes › Incrementing/decrementing and loading presets of Timefactor with midi › Reply To: Incrementing/decrementing and loading presets of Timefactor with midi
#140439
Guybrush
    I’ve done some more intensive test today, and I’m absolutely unable to increment/decrement and load preset using a midi controller.
    I’ve tried the function from H9 software without success : no difference between “increment and load” and “increment” : the result is just incrementing the bank without loading… I don’t want to increment the bank, I want to increment the presets…
    I did the same test on the stompbox itself, and same result : I can increment/decrement bank without loading…
    I’ve tested the Program change midi function, and I’m able to go to different presets, but I have to know which one! In my case, it’s painful : I just want to have a button to increment and load every preset, and another one to do same the same by decrementing….
    Do I miss something?
    For information, the stombox has the 5.2.0.6 firmware.
    Help very appreciated!
