Home Forums Products Stompboxes Basic Presets Reply To: Basic Presets
#140538
    Here are some base presets that I use when I don’t want to lug around one of the racks.  They’re close enough to the AD-220 processing, but there’s no way I can replicate the sound of all of those MN3004 chips.  The delay time ranges are exact, and the FILTER bandwidths add reasonably accurate limitations.  Both DELAYs have duplicated values.
    I adjust the FEEDBACK A & B and MOD DEPTH / MOD SPEED to fit the situation.  DELAY A & B times are mapped to the expression pedal, and authentically ‘bend in pitch’.  WET MIX (“Delay Level” in the AD-220) to taste.
    • Effect Type: Delay
    • Delay Range 20 ms – 500 ms [@ 700 Hz]
    • Delay Range 15 ms – 150 ms [@ 2.5 kHz]
    • Delay Range 10 ms – 75 ms [@ 5 kHz]
    • Effect Type:  Flanger
    • Delay Range 1 ms to 22 ms [5 kHz***]
    • (1 ms – 13 ms in some inaccuarte vintage advertisements)
    *** OK, so I cheated on the 5 kHz. limits.  I like to hear the ‘thru-0’ accents on the multiple-waveform flanging in all of their glory.
