Home › Forums › Products › Stompboxes › Time Factor: OUTPUT 1 less volume than OUTPUT 2 when in stereo › Reply To: Time Factor: OUTPUT 1 less volume than OUTPUT 2 when in stereo
September 14, 2015 at 5:38 pm
#140560
Are you running a stereo signal into the TimeFactor or a mono signal? When you look at the input and output level meters in H9 Control (for instance), do you see the level difference there that you're hearing?
