Home Forums Products Rackmount Configuring H8000FW for dual-stereo using ADAT Reply To: Configuring H8000FW for dual-stereo using ADAT
#140561
    Hi Stephen
    I have attached a document that takes you through a routing setup process, and hopefully, this, along with Mr.Finger's comments, will set you on the route to Routing Comprehension.
    If you still find it confusing, I would recommend User Manual immersion. It is probably easier to understand things using the Routing Utility than using the H8000 front panel.
