Home › Forums › Products › Stompboxes › Space Pedal: Disabled Knob Functionality › Reply To: Space Pedal: Disabled Knob Functionality
September 17, 2015 at 6:37 pm
#140606
Jslimm wrote:
Hi all!
I somehow created a way to scroll through parameters using the X Knob only and adjusting each parameter individually using the Encoder. I need a solution to disable this and restore the use of all 11 knobs again. Tried restoring factory settings and couldn't correct this.
Thanks for your assistance!
J
If you press and hold X, Y, or Z it will toggle that button from Simple to Expert mode. Expert mode lets you scroll through all the parameters with an X, Y, or Z button.
