Home Forums Products Stompboxes Could not reach Eventide server Reply To: Could not reach Eventide server
#140646
Paradox
    Ok, I’ve used the procedure described:
    So, if you’ve installed H9 Control, you should be able to find a link to the Eventide Direct Updater under H9 Control’s folder in Windows start menu.  (Or you could also just download the latest version from the support page;  just select any of the factor pedals as the product to get the links for downloading the Eventide Direct Updater.)  You’ll want to boot your H9 into update mode by starting it up with the HotKnob switch in the upper left hand corner of the H9 pressed before connecting it to the Eventide Direct Updater.
    All works fine! Crunch station is here!
    I’ve a question OT, a very noob question, I don’t know if is useful to open an other thread. There is no possiblity to setup a global output volume instead of per-preset? I’ve to notice that a lot of preset are too much loud (using bass guitar), so setup global volume would be nice.
    Thanks, bye
