Home Forums Products Stompboxes H9 aux switch settings won’t save Reply To: H9 aux switch settings won’t save
#140700
    I fear this may be a hardware problem. Hopefully not. A few questions:
    1) Are you using the supplied power supply ? If not, try it.
    2) Does anything else fail to save ? For example, when you power it up, does it come back with the same preset as when you shut it down ?
    3) To power it down, do you unplug the power lead from the H9, or do you unplug the wart ? If the first, try the second.
