Home › Forums › Products › Stompboxes › Strange mix behaviour › Reply To: Strange mix behaviour
September 28, 2015 at 1:19 pm
#140742
Is the footswitch you're using a MIDI footswitch or an Aux switch? If you're receiving MIDI into your H9, I believe there's a default assignment of a particular MIDI CC to parameter 1; you should turn that off. (You can find that in H9 Control under Pedal Settings / MIDI Settings / Assign MIDI CC messages to Pedal Functions.) In fact you might as well turn off all of the assignments of MIDI CCs to parameters 1 – 10 and anything else in the MIDI CC assignment page that you're not using.
Also, you don't have global mix enabled correct?
