Home › Forums › Products › Stompboxes › H9 aux switch settings won’t save › Reply To: H9 aux switch settings won’t save
September 28, 2015 at 4:38 pm
#140755
nickrose wrote:
I fear this may be a hardware problem. Hopefully not. A few questions:
1) Are you using the supplied power supply ? If not, try it.
2) Does anything else fail to save ? For example, when you power it up, does it come back with the same preset as when you shut it down ?
3) To power it down, do you unplug the power lead from the H9, or do you unplug the wart ? If the first, try the second.
1. Yes, using supplied power supply
2. Does not come up with same preset when powering up
3. Have tried both ways; no success.
Thanks for your continued help in this matter.
Best,
chris
