Home › Forums › Products › Stompboxes › Gigrig G2 and H9 › Reply To: Gigrig G2 and H9
October 2, 2015 at 2:06 pm
#140826
The Gigrig is such a complicated thing it's hard to say. There are plenty of people though using that with the H9 without any problems. So, there's no fundamental problem with using the two together. I don't know a lot about that product. Does it allow you to keep a separate dry path and mix that with a signal going through a stompbox? That would result in a phasey sounding signal… Generally speaking with feedback, you'd want to check whether you've actually set up a feedback loop, no?
