Home › Forums › Products › Stompboxes › Bugs with Advanced Looper Use in 5.2 – and some suggestions? › Reply To: Bugs with Advanced Looper Use in 5.2 – and some suggestions?
October 9, 2015 at 5:32 pm
#140967
Thanks for the reply Nick… BUT – the main issue I have that seems like an error (the PUNCH functions not working properly when I hold down the AUX switch) is not assigned to the Tip/Ring 3rd switch. It is actually assigned to the 1st switch (Tip).
I did try that function on the other switches of the AUX switch, and it continues to exhibit the same behavior. Can you replicate this over there, or do you get the AUX switch to hold the PUNCH function properly?
Please let me know and thanks – would really like to have this issue settled…!
