Home › Forums › Products › Stompboxes › H9 Control doesn’t remember state of Bypass Enabled. › Reply To: H9 Control doesn’t remember state of Bypass Enabled.
October 12, 2015 at 1:42 pm
#140995
jnorris wrote:
No. Mine will not stay on Yes. I can set it, but as soon as I switch to another screen and come back it is on no again.
Is your H9 itself switching between active and bypass correctly? When you change the settings in this screen, do you see the red led above the active switch change as well? (If your bypass mode is set to 'relay', you should also hear a click as switch from active to bypass or bypass to active.)
