Home › Forums › Products › Stompboxes › Using H9 as an External Audio Effect in Ableton. Please help me › Reply To: Using H9 as an External Audio Effect in Ableton. Please help me
Thank you for your answer
Is hard to tell, don’t think its pahse cancellation though. The effects (presets) seem to all sound the same and not drastically changing the sound.
My latest theory is that, if I connect my analog synth directly to the H9 inputs and then the H9 outputs into my Audio Interface it works fine. My fear is that by sending already converted digital signal from Ableton into the H9, the H9 is expeting an analog singal instead of digital, and digital with digital is what is affecting. Is this assumption correct?
Other things I am testing is using the Kill Dry option.
Basically my question now is, can the H9 be used as an External Audio Effect in ableton live where the signal its receiving is digital?
Or if you could please provide a basic configuration example to set this up would be much appreciated.
Thank you very much
Adrian
