Home Forums Products Stompboxes Powering the Factors at 12V/300mA Reply To: Powering the Factors at 12V/300mA
#141163
camilok
    The advice I would give you is that the voltage on your supply needs to match the voltage required on the pedal, and you should always feed more ma than required.  The pedal will only use what it needs, but if you dont give it enough available amperage, you might damage your pedal.  I dont know the polarity on your pedals, make sure you know what is positive and negative before you start a small structure fire.
    That being said, A Voodoo Labs Pedal Power digital has a pair of 9v/12v 400ma outs which should suit yor needs, plus a pair of 9v 400ma outs (all isolated too) for more pedalboard goodness, like perhaps a Pair of H9’s?  (Reverse tip for those!)
