Home › Forums › Products › Stompboxes › H9 Output Levels › Reply To: H9 Output Levels
#141205
    mcmullers wrote:
    1. What type of output does the H9 produce? Line Level or Instrument Level
    It will essentially give you much the same level out as you put in. Note that it does not enjoy a very hot line level.
    mcmullers wrote:
    2. Balanced or Unbalanced
    Unbalanced.
    mcmullers wrote:
    3.If I am connecting the 1/4 outputs to an audio interface to bring them to the daw, should I use balanced 1/4" to male XLR cables for best quality, my audio interface accepts both 1/4 and XLR.
    It really depends on the audio interface. Ideally try both and see what works.
