Home Forums Products Plug-Ins H3000 Factory presets do not recall correctly after Anthology update Reply To: H3000 Factory presets do not recall correctly after Anthology update
#141207
offaxis
    Hi Tom — answers below
    -It sounds like you are using the .tfx presets that are in the Pro Tools built in manager, is that correct?
    YES
    -When you say they aren’t recalling correctly, do you mean that the settings are different in between session loads, or simply when moving from the TDM version of the plug-in to the Native version?
    I am in PT11.3.2 HDX [non TDM] — when I load a .tfx preset [created prior to the Anth X updates] from the menu at the top of the plugin window it does not load correctly. It gets it pretty close 🙂 — from my limited testing it appears to be parameters assigned to the Softkeys 1,2,3,4 that do not recall as they were saved.
    -Did you have a previous native version of H3000 Factory where they recalled correctly?
    I was using the most recent [pre-Anthology X] AAX version of H3000 Factory
    best, Chris
