Home › Forums › Products › Plug-Ins › H3000 Factory presets do not recall correctly after Anthology update › Reply To: H3000 Factory presets do not recall correctly after Anthology update
October 22, 2015 at 8:39 am
#141220
hi Dan
I attached a H3000 preset [REMOVE THE .TXT PART OF THE FILENAME TO LOAD IN PROTOOLS 11.3]
the preset was created with the pitch shifter values set to + – 9
instead they load at + – 100 [with the softkeys set to max values]
