Home › Forums › Products › Stompboxes › Saving a Looper preset with different Depth value › Reply To: Saving a Looper preset with different Depth value
October 23, 2015 at 3:16 pm
#141248
spaceJam wrote:
… By the way, [SMOOTH] is not on the manual, it should be after [CHROMATIC] in pg.7 I think.
https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/Looper.pdf
[SMOOTH] is noted as a 1% increment, with the list below that giving musical intervals + percentages. As for reset to [OCTAVES], I’ve always assumed that was the default intended behavior. Same page of manual:
“Note: During loop recording, Resolution will always return to OCTAVES. This guarantees that the immediate playback speed occurs at the recorded speed.”
FWIW, I use the H9 Control app 95% of the time for setting up presets. It’s so much easier. Most live control has already been pre-configured to happen over MIDI. I will check back the [OCTAVES] behavior using the H9 itself, as time permits.
