Reply To: Saving a Looper preset with different Depth value
Home Forums Products Stompboxes Saving a Looper preset with different Depth value Reply To: Saving a Looper preset with different Depth value
#141259
spaceJam
wedelich wrote:
we did this because most people prefered their immediate playback to be at the pitch/speed they recorded it in (more standard Looper usage).
That said,  a simple workaround is to change the speed resolution after you start recording with an expression pedal, aux switch, midi cc, etc.
Okay, I can understand that. And I will be indeed starting the playback at the same pitch/speed I used to record the loop, I just thought it was strange that one can store per preset other values like Playback, Decay, Filter but not the Speed/Resolution.
And yes, I’ve been sending a CC to change the value to SMOOTH after I record a loop and I’m OK with that, I just was wondering if that was a “feature”.
Thanks guys!
