Home Forums Products Stompboxes Powering the Factors at 12V/300mA Reply To: Powering the Factors at 12V/300mA
#141264
Alancarl
    Hey Dio,
    This must be a sizable pedal board if you are using the other two power supplies for ‘everything else’!
    I keep trying to live with a small pedal board but I am always trying to fit one too-many stompboxes into the mix:-)
    I guess it helps keep the gear business going…
    Also even here that current doubler cable is not readily available… I’ve often wondered if Eventide would give us the option to have the lights go on sequentially at startup… I’m pretty sure it’s a corporate policy to give us that cool lighting blitz as most of the Eventide devices I’ve encountered crank up the burners as a hello world gesture!
    Rock on !
    Al
