Home › Forums › Products › Stompboxes › H9 midi setup question › Reply To: H9 midi setup question
October 26, 2015 at 2:41 pm
#141276
Hi, I have a little question:
apparently I can correclty set the H9 in tuner mode via MIDI PC#124: TUNER label appears in the screen after sending the command.
Bu then t nothing else happens, that is, tuning doesn’t actually engages, until I send a second midi PC#125 (which corresponds to ACTIVATE?).
am I doing something wrong? Is it the correct way to engage the tuner via midi (I mean, with two midi PC messages instead of one)?
NB H9 is in pre/post and I am using an musicomlab MKIV as controller.
thanks in advance for your help in clearing my doubts out
