Home › Forums › Products › Stompboxes › TimeFactor System Settings Do Not Save › Reply To: TimeFactor System Settings Do Not Save
#141299
    Make sure that you are using the supplied power supply. If you are, it sounds like a hardware problem and will have to come back. Sorry.
    We've had a few cases where manufacturing has put in the wrong part (which has the same number as the right part) which can cause this.
