Home › Forums › Products › Plug-Ins › Anthology X VST Scan Hang With Sonar Platinum 21.9.00 Build 40 Jamaica Plain – x64 › Reply To: Anthology X VST Scan Hang With Sonar Platinum 21.9.00 Build 40 Jamaica Plain – x64
Hi Lunatek-
Thank you for the info. I am fairly sure this is related to an issue we had with some corrupted libraries on certain configurations of Windows, which we plan to have a fix for on Monday – I will let you know as soon as it is ready.
As far as the dropdown menu appearing behind the plug-in, I haven't seen that behavior. Does it occur right when you click the drop down, or if you click the dropdown and then somewhere else in the DAW or plug-in?
We don't have an uninstall feature yet, but if you've moved the 32-bit plug-ins to a custom folder, then simply remove them from that folder.
Best,
Tom
