Home Forums Products Plug-Ins Anthology X VST Scan Hang With Sonar Platinum 21.9.00 Build 40 Jamaica Plain – x64 Reply To: Anthology X VST Scan Hang With Sonar Platinum 21.9.00 Build 40 Jamaica Plain – x64
#141340
Lunatek
    TLongabaugh wrote:
    As far as the dropdown menu appearing behind the plug-in, I haven’t seen that behavior. Does it occur right when you click the drop down, or if you click the dropdown and then somewhere else in the DAW or plug-in?
    Yes, it happens right when I click the drop-down box.
    Best,
    Stephen
