Home › Forums › Products › Stompboxes › Newbie with “try” problem › Reply To: Newbie with “try” problem
#141431
gkellum
    Have you upgraded your H9's software recently?  If so, you might want to clear it's system settings.  This will wipe out any changes to system settings you might have made but won't affect your presets.  You do this by turning your H9 off and then turning it on again with the right footswitch and the HotKnob button pressed (the button in the upper left hand corner of the H9).
