Home Forums Products Stompboxes Space pedal – Volume spikes when changing preset. Urgent help required! Reply To: Space pedal – Volume spikes when changing preset. Urgent help required!
#141515
    Not quite sure what is causing your problem, but you should try setting SPILL to 0 or OFF. Experimenting with KILLDRY may also be helpful.
    Make sure that you are using the latest software version (5.2) – there were problems in this line with earlier versions.
