Home › Forums › Products › Stompboxes › Space pedal – Volume spikes when changing preset. Urgent help required! › Reply To: Space pedal – Volume spikes when changing preset. Urgent help required!
November 13, 2015 at 6:43 pm
#141535
nickrose wrote:
Not quite sure what is causing your problem, but you should try setting SPILL to 0 or OFF. Experimenting with KILLDRY may also be helpful.
Make sure that you are using the latest software version (5.2) – there were problems in this line with earlier versions.
Thank you for the reply! Turns out my pedal was still on SW version 4.0.0. Just did an update, seems to be much better now!
Thank you so much, this has made my day.
