Home Forums Products Stompboxes Increased Lag When Switching presets with Version 5.0.0? – Pitchfactor Reply To: Increased Lag When Switching presets with Version 5.0.0? – Pitchfactor
#141558
gkellum
    sshep7 wrote:
    Went back to 3.5, now can't switch between presets with knob.  Stuck on Diatonic.  Email me last software update without latency issues,maybe 4.5?
    Ok, actually, there was a 4.5 release.  I just added that 4.5 release as well as the more recent 5.1 release to the Eventide Direct Updater.  So, you should be able to download and install those releases from that app.
    As I was testing to make sure those releases download and install correctly, I also saw the problem you described with the preset selector knob not working.  In my case resetting the system settings as I described above fixed the problem.  Hopefully, it did so for you as well.
