Home › Forums › Products › Stompboxes › Space patch – RV5 Modulation setting? › Reply To: Space patch – RV5 Modulation setting?
This might be an unorthodox choice, but the Shimmer algorithm adds a bit more “bloom” to the reverb that I like. The subtle modulation comes from slight, complementary pitch shifts. The expression pedal spreads these shifts to more than a quarter tone each way. The HotSwitch jumps to +/- one octave with a deeper mix, as another option. Just because you can …
Expression Pedal Heel: A-PITCH -10 c
Expression Pedal Heel: B-PITCH 10 c
Expression Pedal Heel: A-PITCH -30 c
Expression Pedal Heel: B-PITCH 30 c
HotSwitch OFF: MIX 25
HotSwitch OFF: A-PITCH -10 c
HotSwitch OFF: B-PITCH 10 c
HotSwitch ON: MIX 35
HotSwitch ON: A-PITCH -1200 c
HotSwitch ON: B-PITCH 1200 c
