Home › Forums › Products › Stompboxes › Rng of my AUX Switch not working with H9 › Reply To: Rng of my AUX Switch not working with H9
November 30, 2015 at 7:43 pm
#141679
nickrose wrote:
If you have this problem with this specific switch, you will either need to short out the diode attached to the TIP switch, or wait for a software fix.
Otherwise, make sure that Utils/Exptip is set to SWITCH.
Can you verify this has been FIXED with software upgrade to accomodate such switches w/ diodes?
Thanks,
Show More...Andrew
