Home Forums Products Stompboxes H9 DSP+FX bypass doesn’t Work Reply To: H9 DSP+FX bypass doesn’t Work
#141768
gkellum
    TomViolet wrote:
    Everything works like charm except from the DSP/Fx bypass. when i turn off the pedal from MIDI or even from H9 footswitch itself  effect trails are instantly cut off as if the pedal is in hard or dsp bypass mode
    It would be good to try resetting your H9s system settings by turning it off and turning it on again with the right footswitch and the HotKnob pressed (the button in the upper left hand corner of the H9).  The last update seems to require that the system settings be cleared.
