Home › Forums › Products › Rackmount › Pitch correcting voice input to Midi key pitch › Reply To: Pitch correcting voice input to Midi key pitch
I’m aware of the Midi presets, they do not perform what I am seeking. Yes or No ? Can the H8000 perform adaptive pitch shifting of an input to an ouput pitch defined by a Midi input key (think of it as a custom scale defined in real time by the Midi input key(s)) ? This should be a straight forward Yes or No question. If Yes, then I need more details on how to design the preset if it doesn’t exist.
There is a “MIDI Harmony” preset, but this only shifts by the absolute amount of the MIDI value.
You could modify the sigfile so the “pitch” output of the shifter was subtracted from the MIDI value.
This might give a bit of raggedness at the start of each note, depending how well the pitch detector liked the input signal.
Show More...Show Less...
