Home › Forums › Products › Stompboxes › No audio output when switching from bypass to active. › Reply To: No audio output when switching from bypass to active.
December 19, 2015 at 8:16 pm
#141882
My guess is that this is a problem specific to your setup (or we would have noticed it).
Try setting the H9 to Factory Defaults (see UM), the go through all the MIDI settings, and make sure that everything you don't need is OFF.
I suspect that the Helix is sending something of which you are unaware, and that this is confusing the H9.
