Reply To: Pitchfactor stuck in Update mode. Can’t update with either Direct Updater or Update Utility
Home Forums Products Stompboxes Pitchfactor stuck in Update mode. Can’t update with either Direct Updater or Update Utility Reply To: Pitchfactor stuck in Update mode. Can’t update with either Direct Updater or Update Utility
#141932
gkellum
Well, it would be best to send an email to support@eventide.com.  Let us know if you have access to a Windows machine;  if so, we might send you an alternative updating application.  Otherwise, we might send you the PitchFactor update software so you can try to install that directly with the Eventide Direct Updater on Mac even if the PitchFactor is appearing as an invalid device.  Also, let us know if when you turn your PitchFactor on does the display light up immediately, or is there a 10 second delay before it comes on?
