Home › Forums › Products › Stompboxes › Pitchfactor stuck in Update mode. Can’t update with either Direct Updater or Update Utility › Reply To: Pitchfactor stuck in Update mode. Can’t update with either Direct Updater or Update Utility
December 26, 2015 at 10:27 pm
#141936
Got hold of an old PC and used the Direct Updater but the update crashes with an error after around 10% and the Pitchfactor screen says “BAD !!!”.
After that the unit does not power up unless i hold down the middle footswitch to get it back into update mode…if i don’t do this it stays dead and then every 20 or 30 seconds the unit lights up and then dies again.
