Home Forums Products Stompboxes Pitchfactor stuck in Update mode. Can’t update with either Direct Updater or Update Utility Reply To: Pitchfactor stuck in Update mode. Can’t update with either Direct Updater or Update Utility
#141937
gkellum
    luca9583 wrote:
    Got hold of an old PC and used the Direct Updater but the update crashes with an error after around 10% and the Pitchfactor screen says "BAD !!!".
    After that the unit does not power up unless i hold down the middle footswitch to get it back into update mode…if i don't do this it stays dead and then every 20 or 30 seconds the unit lights up and then dies again.
    I just sent you an email with a link to our Windows based updater which may help with your problem.
