Reply To: Pitchfactor stuck in Update mode. Can’t update with either Direct Updater or Update Utility
Home Forums Products Stompboxes Pitchfactor stuck in Update mode. Can’t update with either Direct Updater or Update Utility Reply To: Pitchfactor stuck in Update mode. Can’t update with either Direct Updater or Update Utility
#141965
stringbot wrote:
stringbot wrote:
…but hangs up on "Preparing for update. Checking device…"
Actually I've gotten it past that screen to the install phase a couple of time but the install fails around 20% complete, with the same result described above.
If it always fails at the same point, that would suggest a hardware problem. Maybe there is an error message ?
